I tore everything apart before I measured the offset - Doh!
Anyone have any numbers to get me started?
Thanks,
Byrd
cb77 front and rear wheel offset
Re: cb77 front and rear wheel offset
TORE WHAT APART?. ......lm
byrdman76 wrote:I tore everything apart before I measured the offset - Doh!
Thanks,
Byrd
Both rims front and rear. I took the spokes out of the rims and separated them from the hubs before I measured the off set.LOUD MOUSE wrote:TORE WHAT APART?. ......lm
Thanks,
Byrd
Do you have any measurements LM?
When ya see a hub with one side where the spokes install has a larger diameter than the other (MAICO) ya may see that the rim isn't centered to the hub. Usually ya will find that when all spokes have the same amount of threads in the nipple that the hub will be centered. ............lm
byrdman76 wrote:How come others speak of offset on the forum? Do some aftermarket rims require you to offset the hubs and the OEM' do not? Not doubting you, just looking for some education ;)cknight wrote:No offset, rims should be centered on hubs. Regards, Chase
Thanks for the explanation LM.LOUD MOUSE wrote:When ya see a hub with one side where the spokes install has a larger diameter than the other (MAICO) ya may see that the rim isn't centered to the hub. Usually ya will find that when all spokes have the same amount of threads in the nipple that the hub will be centered. ............lm
