Hello,
I just took apart the and cleaned the carbs, when was putting them back on i ran into an issue with the banjo bolt that feeds the gas into the carbs. Ill begin to screw the bolt into the carbs and it will begin to tighten and then all of the sudden its completely loose again. When i looked at the bolt there was some thread that was coming off, itlooked it had been painted on.
Was this some kind of old thread repair?
How can I repair this?
Are you supposed to use crush washers on this? Thanks,
DG
Fuel Line into Carb Banjo Bolt
Re: Fuel Line into Carb Banjo Bolt
Take a good look at the threads in the carb body.
I suspect they are not good. ..............lm
djg422 wrote:Hello,
DG
