Oil in Left side crankcase
paperslammer
Post by paperslammer » Sat Aug 21, 2010 2:59 am
This might be totally normal, but as I was cleaning out my oil filter I notice a good amount of oil standing in the bottom of the left side crank case. Is this normal or do I have a leak? About 3 of my screws are stripped so I'll have to get them off somehow to check this out if it is a problem. Thanks!
'64 CA77 305 Dream
Post by e3steve » Sat Aug 21, 2010 7:45 am
Left-side crankcase shares the sump oil to lube the primary chain/clutch system.
paperslammer
Post by paperslammer » Sat Aug 21, 2010 12:27 pm
e3steve wrote:Left-side crankcase shares the sump oil to lube the primary chain/clutch system.
Hooray it's normal!
'64 CA77 305 Dream
Tango911
Post by Tango911 » Sat Aug 21, 2010 1:18 pm
look up a helicoil thread insert kit. easy fix for your stripped bolt holes and you can use the same size bolt. If you didnt already know.
you have to order it with the right size of course.
65 Sears Puch 250
69 Dream 305
74 Kawi H1
78 CB750 SS
Post by LOUD MOUSE » Sat Aug 21, 2010 1:40 pm
I may be wrong but I think the heads of the screws are stripped not the threads. ........lm
Tango911 wrote:look up a helicoil thread insert kit. easy fix for your stripped bolt holes and you can use the same size bolt. If you didnt already know.
Tango911
Post by Tango911 » Sat Aug 21, 2010 3:38 pm
you could be correct :) i assumed they might be turned in and stripped and hard to get back out, as mine where on my xr250. But yes, new bolts would be a nice easy fix eh?
gl
65 Sears Puch 250
69 Dream 305
74 Kawi H1
78 CB750 SS
Re: Oil in Left side crankcase
Post by e3steve » Sun Aug 22, 2010 6:56 am
paperslammer wrote:About 3 of my screws are stripped so I'll have to get them off somehow to check this out if it is a problem. Thanks!
With the original casing screws in place, an impact driver (with the correct size & type of bits -- Phillips 2pt for the side casing screws) and/or a Dremel are essential tools to have in your collection.
