I do not understand how to remove the rotor
silverclerk@gmail.com
Post by silverclerk@gmail.com » Fri Oct 15, 2010 9:41 am
I have looked at many previous posts and I am still not smart enough to figure it out. My engine was running, made a loud squeak.then was stuck. I took the right side engine cover off, and the engine could turn, squeak disappeared. I can see that the chain from the rotor to the starter motor seems to loosen up when turning the crank and kind of makes the engine stick. Therefore I want to take the stator and rotor off to look back there. The puller I see people recommending on here is just a bolt, don't I also need something to lock the rotor in place? It seems to me that I must lock the rotor in place so I can remove the bolt holding the rotor on, then screw the puller bolt in to that hole to remove the rotor. Is that right? Thank you
NYC
Last edited by silverclerk@gmail.com on Fri Oct 15, 2010 11:53 am, edited 1 time in total.
Post by e3steve » Fri Oct 15, 2010 11:49 am
First & foremost: please edit-in your geo-location within your profile.
OK, down to business-
  • Bike on centre-stand, roll the rear wheel by hand and and lift the shift pedal into 2nd gear
    Place a wooden pole (a broom handle works) through the rear wheel spokes, close to the rim and under the mufflers (or swing arm)
    With a 14mm shallow socket on a ratchet, wind the motor a/c/w with the rotor bolt until the pole locks the wheel
    Once all the slack in the drive is taken up, swap the ratchet for a 14mm ring spanner (wrench), placing it at a convenient attitude, and smack it a/c/w with the palm of your hand
    Remove the rotor bolt
    Remove the r/h muffler, motor casing and stator
    Screw in the puller bolt (assuming you already have one) and wind it as tight as you can whilst holding the rotor by hand
    Give the puller bolt a sharp blow on its head with a heavy hammer (not a dead-blow or soft-faced type)
Pop!
Post by silverclerk@gmail.com » Fri Oct 15, 2010 12:01 pm
Great, thank you kindly. One more question if you don't mind, what does "a/c/w" mean?
Thanks
Post by e3steve » Fri Oct 15, 2010 12:03 pm
Anti-clockwise; I guess you'd say 'counter-clockwise'?
Thanks for editing, btw.
Post by silverclerk@gmail.com » Fri Oct 15, 2010 12:14 pm
Great, thank you so much for your help and no problem on the editing. Later
Post by davomoto » Fri Oct 15, 2010 12:33 pm
An impact gun works well for this also, either electric or pnuematic. Save the broom handle some grief as well.
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
Post by e3steve » Fri Oct 15, 2010 2:15 pm
I must get one of those, one day!
