Cable problems
bonjour
Cable problems
Post by bonjour » Mon Oct 18, 2010 1:11 pm
Hello people,
I have trouble with routing my brake and clutch cable properly.
I have a little 'sports steer' (ja, sorry for my bad English) and I have levers of a Suzuki GS (old type) , the problem is that the cable's (both brake and clutch) , don't go nicely around the corner behind the headlight.
I don't have a nice solution for it, but I was thinking of something like the little bend thing the trottle cable has, before it enters the trottle twist. A bend like that, only then for the brake and clutch cable.
But I don't know if something like that exists ? I think something like that would solve my problem's, but I don't know if there are other ways of solving this problem.. ? So idea's are welcome !
Here's the pic. wich will make my problem clear : ( the cable is long enough, it's tight because of the sharp corner it has to make )
Post by G-Man » Mon Oct 18, 2010 1:53 pm
Hi Bonjour
My Triumph Daytona 955 has a metal cable guide on the clutch cable. It may be possible to buy an old cable and use the parts to make up a special cable for the Honda.
Here is an eBay link to one for sale.
http://cgi.ebay.co.uk/clutch-cable-triu ... 1751wt_907
bonjour
Post by bonjour » Mon Oct 18, 2010 1:56 pm
Ja ! That's just seems like the thing I need.
Now I have a point to start, thanks man, Tomorrow im going to find out more about it. ll keep you guys posted on this.
Thanks !
jensen
Post by jensen » Mon Oct 18, 2010 4:13 pm
What's wrong with the original low bar tube ? (in dutch "stokstuurtje")
If fitting that kind of steering, there are no problems to solve.
Re: Cable problems
Post by LOUD MOUSE » Mon Oct 18, 2010 10:42 pm
I'd say ya do need a cable which is about 3 inches longer. ....lm
bonjour wrote:Hello people,
Post by e3steve » Tue Oct 19, 2010 5:49 am
IMO if you intend keeping the Thruxton handlebar then you should look at routing a longer cable around in front of the instrument cluster and back down between the bucket and the top yoke; that's a nasty exit angle from the lever perch(es).
I'd attack it first by measuring the route for the clutch cable on full left-lock and the front brake cable on full right-lock, leaving enough space, at each lock, between the tighter cable and the instruments' binnacle to insert a finger in between.
Thruckers ('Thruxton' handlebar) and clip-ons usually present this sort of cable routing problem!
brewsky
Post by brewsky » Tue Oct 19, 2010 9:38 am
Might look at a CA77 Dream cable with the pre-bent end.
They are available in at least a couple different lengths. (44" & 52")
http://www.olypen.com/retro/
