WHERE IS MY VIN NUMBER??
rrtccp
Post by rrtccp » Sun Oct 31, 2010 6:07 pm
I have been told that the number stamped on the left side of the engine case is not the VIN number... i was told that there is a separate number on the chassis somewhere,, can some one tell me where to look on my dream and superhawk... i will be ordering a copy of the bill silver restorations books , but i would like to get started while i'm waiting for the books... tomorrow i will post my actuall engine case numbers... thanks , in advance,,, also guys if anyone is interested in OEM never installed honda exhaust pipes for the super hawk or dream check the for sale forum, i posted a couple of pics.... np
brewsky
Post by brewsky » Sun Oct 31, 2010 6:24 pm
On the Dream it is stamped vertically on the frame near the left driver footpeg.
Post by davomoto » Sun Oct 31, 2010 8:14 pm
Cb77 it's stamped on the left side of frame head tube.
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
rrtccp
My VIN
Post by rrtccp » Sun Oct 31, 2010 8:45 pm
Hey dav, thanks for the advice,, i found the chassis numbers... the superhawk frame # CB 77 1027881, the engine # CB 77 E 1037926............. the dream numbers frame CI 78 105343.......
and engine # CA 77E 105351....... is there any signifigance with the dream engine and frame numbers being so close and the superhawk frame and engine numbers being quite a bit further apart... do you know how the numbers break down,,, can we tell when exactly the bikes were built..... when i used to restore mid year corvettes there was the bible of restoration, which allowed you to break down the vin numbers and work backwards knowing how many cars were built per day and you could tell the day and almost to the hour when your car was built... any thing simular with the honda's... i'm hoping the bill silver books have way more info than i have now... thanks bro...np
cyclon36
Re: My VIN
Post by cyclon36 » Mon Nov 01, 2010 7:29 am
rrtccp wrote:Hey dav, thanks for the advice,, i found the chassis numbers... the superhawk frame # CB 77 1027881, the engine # CB 77 E 1037926............. the dream numbers frame CI 78 105343.......
No significance of them being so close. That just means that it's probably the original engine as the engine ID is usually only a few numbers away from the VIN. Engines and chassis hardly ever matched up. There was the occasional perfect match which is significant and can bring a higher value. If the numbers are quite a ways off like your CB, that usually means the engine has been replaced.
Re: My VIN
Post by e3steve » Mon Nov 01, 2010 7:55 am
Nick, your CB is '65 or '66; look at the harness tag beneath the tank (tank has to be removed) to narrow it down. Looks like it has been re-motored at some stage.
Your Dream is a '64.
