what size the fork by mm if the fork ears are taken off
im trying to put clip ons on my cb77, i dont know how many mm it is
Re: what size the fork by mm if the fork ears are taken off
Measure where ya going to mount them. ..........lm
drucb77 wrote:im trying to put clip ons on my cb77, i dont know how many mm it is
was hoping someone would know haha
ok ill go measure it
cyclon36
- Contact:
I'm probably off by 1mm then. My harbor freight caliper's battery is dead so I'm relying on the super precise plastic measuring mark on the side :-)e3steve wrote:They'll be either:
- 38mm (early forks)
or
34.5mm
or
33mm (alloy lower legs)
Steve, I have both sets of forks, the steel lower and the aluminum lower. Both of them measured the same diameter at the top.
- h305 Moderator
Hmmm, interesting anomaly. According to Silver (Honda) data, type-2 forks (alu lower legs, external springs), introduced at CB77-1030130, are the only fork legs to have 33mm constant diameter from top to bottom. Steel lowers indicate type-1 forks, still 33mm below the lower yoke but internal springs and greater, beefed-up diameters upon entering the lower yoke.
Now I'm perplexed.... But, as lm says, "once it's printed, you can't change it"!
