Starter Clutch question.......
brcree
Post by brcree » Mon Oct 29, 2012 3:39 pm
I have this situation going in the Eng forum as well. When starting: (69 305) I hear a loud CLACKING/KNOCKING sound as it tries to start. When it is running the sound is not there. I was told it might be the starter clutch. I have removed it and taken a look inside it. All the small parts are there, and yes they do fall out. If the small springs a weak will it cause the clutch to make this loud clacking noise I'm hearing?...Thanks for any help.
In God we trust!.....Nothing like some breeze on the knees!
Re: Starter Clutch question.......
Post by LOUD MOUSE » Mon Oct 29, 2012 3:59 pm
Yes.
They usually break and are short. .....lm
brcree wrote:I have this situation going in the Eng forum as well. When starting: (69 305) I hear a loud CLACKING/KNOCKING sound as it tries to start. When it is running the sound is not there. I was told it might be the starter clutch. I have removed it and taken a look inside it. All the small parts are there, and yes they do fall out. If the small springs a weak will it cause the clutch to make this loud clacking noise I'm hearing?...Thanks for any help.
brcree
Clacking.........
Post by brcree » Tue Oct 30, 2012 4:06 am
Thanks LM...I can always count on you! I suppose these springs we speak of are near impossible to locate!
Post by G-Man » Tue Oct 30, 2012 4:22 am
Still available from Honda. Get a new set of rollers and springs.....
http://www.davidsilverspares.co.uk/C77- ... rt_196192/
Re: Clacking.........
Post by LOUD MOUSE » Tue Oct 30, 2012 7:02 am
I think they are available from HONDA.
If not Hoosier Tom had some a while back.
If the rollers are not damaged no reason to replace.
Terry at Western Hills Honda would be my choice for these parts. .........lm
brcree wrote:Thanks LM...I can always count on you! I suppose these springs we speak of are near impossible to locate!
rzgkane
Post by rzgkane » Tue Oct 30, 2012 11:42 am
I bought the cups, rollers and springs right from my local HONDA dealer six months ago. Make sure to fish out any fragments of broken springs that are almost certainly still lurking in the body of the starter clutch before you try to put it back together.
You will need to rotate the entire assembly clockwise when trying to get the rollers to go back into their little hiding spots and the clutch seated onto the starter sprocket. This means that you will need to start the rotor's slot for the keyway about 1.5-2 hrs. before the keyway to achieve simultaneously starter clutch and keyway seating.
1965 CA77Dream
