I have a grab handle that mounts to the frame tube by the ignition, but I'm missing the back part that it bolts too. Is anyone holding?
I'll just make one if I can't find one.
CB77 Grab handle bracket
JSharpPhoto
- h305 Moderator
Your geographic location please. More members may be inclined to be helpful with said info.
If you fabricate the part it's worth bearing in mind that the clamped handle can twist on the frame tube, damaging the finish. An M6 x 15mm machine screw, drilled & tapped through the rear clamp and into the frame tube, will prevent the handle twisting.
Good luck in your task!
JSharpPhoto
