Is my CA77 Dream running an over bore motor?
black55tbird
Post by black55tbird » Wed Dec 18, 2013 2:09 pm
I just removed the head and cylinder on my 1964 Dream and measured the bore with a caliper and it is just under 63 cm.... and I expected to see just over 60 cm. One of the pistons is marked on the side with CB77.
I don't know much about cylinders etc but these look a little thin to me.
Anyone have any clue to what have going on here?
Re: Is my CA77 Dream running an over bore motor?
Post by LOUD MOUSE » Wed Dec 18, 2013 5:54 pm
What numbers are on the top of the piston?. .....lm
black55tbird wrote:I just removed the head and cylinder on my 1964 Dream and measured the bore with a caliper and it is just under 63 cm.... and I expected to see just over 60 cm. One of the pistons is marked on the side with CB77.
black55tbird
Post by black55tbird » Wed Dec 18, 2013 9:13 pm
Pistons say Japan 3.00 on the tops. That's all I can find.
Hoosier Tom
Post by Hoosier Tom » Wed Dec 18, 2013 9:33 pm
You've got a 63mm big bore kit installed some time in the past, so yes, your liners would look a little thin. 4th over on a 305 is 61mm.
HT
black55tbird
Post by black55tbird » Wed Dec 18, 2013 9:43 pm
Interesting. So since I need to freshen it up with new pistons and rings what, if anything can I do? One cylinder has a little wear so I will need to bore this out. Can I go a little larger with these cylinders? Are there any pistons and rings to fit?
Thanks, Craig
Post by G-Man » Thu Dec 19, 2013 4:43 am
Might be simpler to get a replacement barrel or liners. You then have a lot of options to work with.
malcolmgb
Post by malcolmgb » Fri Dec 20, 2013 6:42 pm
G-Man wrote:Might be simpler to get a replacement barrel or liners. You then have a lot of options to work with.
Graham is it possible to get liners in the UK I may be in a similar position.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
