Hello everyone,
When I fire up my 1966 305 CA77 Dream the engine just takes off and idles at what seems to be 2500 RPM!
I have had the carb apart:
- I have checked numerous times that I have the slide in properly
- I have replaced the throttle cable and made sure that it slides easily and returns to the home position, the end of travel.
- I replaced the O-rings on the base of the carb and on the other side of the spacer
- Inspected spacer for cracks, there are none.
- My float bowl and carb top gaskets are in good condition and do not leak (not as far as I can tell)
- The air bleed screw has no effect BUT the idle screw does have a slight effect.
It behaves like the throttle is open. I can rev it up with no hesitation but I have a terribly high idle that I cannot bring down to a normal level. Any help would be appreciated. I have automotive experience but this one has me baffled at the moment.
Thank you all,
High Idle
rustywrench
high idle
Spray a generous amount of a non flammable liquid at the base of the carb. Any change in RPM will tell you where the problem. Air leak causing a lean condition. Sometimes the carb base will distort from over tightening. If in fact that is the case, somewhere on this forum there is a thread designated to checking the flange for flatness and sanding to correct it. Also I remember reading a thread about a slide that was excessively worn and passing too much air. Just a couple more places to focus your attention. Rusty
If none of the suggestions given so far work, here are a couple things I'd check. These are separate things and NOT a list of sequential steps. Just trying to think of things that might cause this.
- Check the O-ring on the air mixture screw.
- Back the slide stop screw out all the way. This is what you are calling the idle screw.
- Remove the cable from the slide and reassemble the carb. See if the idle is still high.
- Drop the bowl and make sure the pilot jet has not fallen out.
- Check the centrifugal advance to make sure it is not stuck fully advanced.
Let know if you solve this and what caused it.
regards,
Rob
regards,
Rob
Wonderful!
These are the ideas I needed.
- I checked the o-ring at the air bypass screw....it was missing! I think I may be on to something but I have a bit of a dilemma. My Clymer manual shows the o-ring between the spring and the threads of the screw. This doesn't seem to work. There is a groove just under the head of the screw and I assumed that must be where the o-ring went. Tried the bike with the new o-ring and no difference. I'm not quite sold that the o-ring is installed correctly though. Do you have a picture of an air bypass screw with the proper position of the o-ring?
I still have yet to check that my timing advance has not jammed in the advanced position.
I will go through the list this weekend.
Thank you very much!
