Camshaft shallow splines
mcconnellfrance
Post by mcconnellfrance » Sun Jun 01, 2014 1:41 pm
I am having to replace the cam shafts in my 1965 Honda CB77. A previous rebuilder had 're-profiled' the cams and now they are way below the specification lift!
The only available cams I can find are the later shallow spline pt nos. 14121-268-060 left and 14111-268-030 right. Has anyone successfully fitted these cams to the older deeper cam sprocket splines? I guess that the camshaft lock nut and camshaft tapered bolt will pull it up tight?
Thanks for any help you can give.
Brgds
mcconnellfrance
Post by mcconnellfrance » Sun Jul 13, 2014 2:05 am
I found the answer on Bill Silver's advice pages where he says they are not interchangeable. I found a shallow spline cam sprocket and this and the new cams are installed in the head.
Post by G-Man » Sun Jul 13, 2014 2:56 am
Hi
I did send you a reply on the Honda Twins forum.
Glad you have it sorted.
mcconnellfrance
Post by mcconnellfrance » Wed Jul 16, 2014 2:36 pm
G-Man, Thanks very much for your reply and good advice. I have a weeks holiday in two weeks time so will start to carefully re-build the engine and re- install in the bike. I am hoping to get it running again before the summer ends.
I originally removed the engine to replace the points shaft as I discovered that a previous owner's rebuild had installed what looks like a CA points shaft. The points were swapped left with right to make run!
Brgds
