camshaft assembly
mcaleerj
camshaft assembly
Post by mcaleerj » Fri May 08, 2015 3:01 pm
just restored '67 CL77. Right cylinder not running though good spark, rebuilt carbs.(fuel delivery verified) Is it possible to assemble the right and left camshafts in a 180 degree fashion?Can't remember if I took them apart. Seems like the right cyl not sucking in fuel ,cam timing? thankful for any advice.
Post by G-Man » Fri May 08, 2015 3:47 pm
Pull out the plugs, remove the tappet inspection covers and rotate the engine to see if everyting is doing what it should on the correct stroke.
bamacl
Post by bamacl » Mon May 11, 2015 9:24 am
The groves will not allow you to install the cams in the sprocket wrong but quite easy to install the cam/sprocket assembly a tooth or so out.
