stuck clutch
redtr4
stuck clutch
Post by redtr4 » Thu Mar 10, 2016 8:27 am
Think I already know the answer to this but anyone know of way to free stuck clutch w/o disassembly and individually separating the plates? Know from bad past experience that trying to free up by dumping into gear while running not a good idea.... thanks for any suggestions Kurt
DianneB
Post by DianneB » Thu Mar 10, 2016 10:38 am
Mine sticks anytime it sat for awhile so I put it in high gear, take the bike off its stand, and just rock the bike back and forth (but not too hard). That usually gets mine to release.
If that doesn't work for you, you will probably have to remove the clutch.
deafanddiabetic
Post by deafanddiabetic » Thu Mar 10, 2016 10:51 am
My Dream has sat for about 6 months and the clutch was stuck when I fired it up. I just put new gaskets after an engine/transmission rebuild and was hoping to not break that seal again.
I will try this, crossing my fingers!
1964 CA72
1974 BMW R75/6
1969 CL450
redtr4
related topic
Post by redtr4 » Thu Mar 10, 2016 2:09 pm
is there supposed to be a ball bearing between the lifter mechanism and the push rod? I know some bikes have them but I dont have one and dont see on exploded diagram I have.. thanks
Re: related topic
Post by G-Man » Thu Mar 10, 2016 2:34 pm
Yes - 5/16 ball in there...
So how did your front hub problem work out? Did you see my pictures?
redtr4 wrote:is there supposed to be a ball bearing between the lifter mechanism and the push rod? I know some bikes have them but I dont have one and dont see on exploded diagram I have.. thanks
Nick
Post by Nick » Sat Mar 12, 2016 2:26 am
Push start bike, while riding pull clutch in and start applying rear brake, do that for a bit and it will break loose.
d2d
Can't shift out of gear
Post by d2d » Thu Mar 31, 2016 9:13 pm
From cold start bike runs fine and shifts for about 8 miles. Then will not shift out of gear or into neutral. HOWEVER, generally once I turn off the ignition, wait a few seconds, it will find neutral. New development is that if I attempt to shift at low rpms it will, but then even that stops working. The entire shifting seems to have become randomly screwed up to the point where I can't offer any better explanation except that I need to do the obvious: bring the bike to normal shifting. The '65 305 is very well cared for, not abused or even ridden hard. I have owned it since 1974. Help is greatly appreciated.
