picked up this bad boy from a guy that quit mid rebuild kicked over too many times to count got fired up once, rebuilt carbs and set points to the value i was recommended to . now i have no spark.... any ideas besides gasoline and a match? lol
(electrical testing tips)
1967 cl77 no start
Re: 1967 cl77 no start
Please give your address.
If you are in the US please call me at 830-895-0654. ...............lm
tex wrote:picked up this bad boy from a guy that quit mid rebuild kicked over too many times to count got fired up once, rebuilt carbs and set points to the value i was recommended to . now i have no spark.... any ideas besides gasoline and a match? lol
revlover
The cl77's 180 degree firing ignition can be thought of as two separate ignition systems. Do you spark on one cylinder only? If you have no spark on both cylinders, then the problem is common to both systems such as the power feed to the coils. Using a test light, first verify there is power to the positive side of the coils.
