Removing and replacing studs
Tim Allman
Post by Tim Allman » Sat Dec 17, 2016 12:15 pm
Can someone fill me in on the correct method or tool to use to R&R studs? I'm referring to the big ones that hold the top end together as well as the smaller ones such as the exhaust and carb studs.
Thanks,
Tim
Re: Removing and replacing studs
Post by LOUD MOUSE » Sat Dec 17, 2016 12:33 pm
I bought a tool at my NAPA dealer which is apx. 3 inch round, has a place for a 1/2 inch drive ratchet and a hole for the stud to go through.
You put the tool over the stud and when you turn it with the ratchet a wheel grabs the stud.
I caution you the the 2 outer front studs can/will break at times. ....................lm
Tim Allman wrote:Can someone fill me in on the correct method or tool to use to R&R studs? I'm referring to the big ones that hold the top end together as well as the smaller ones such as the exhaust and carb studs.
Thanks,
Tim
Post by G-Man » Sat Dec 17, 2016 1:55 pm
I have a set of stud removal 'sockets' like this.
https://www.machinemart.co.uk/p/laser-s ... 0wodB7kD5Q
Inside each 'socket' is a one-way roller clutch (like the starter clutch) which grips the stud without marking it. They work best on parallel studs so do=nt work so well on those outer waisted ones.
DJM
Post by DJM » Sat Dec 17, 2016 2:02 pm
Evening Graham,
Yes I have a couple of those too, they work as well as anything I've come across.
Gave the CL an outing this morning, a bit chilly (4 c) but had a good run into the Peak District for lunch about 70 miles in all!
Post by G-Man » Sat Dec 17, 2016 2:25 pm
Envious....
Just got back from my latest US trip. Spent the day putting up Christmas lights, washing cars and shopping. Maybe some bike fun later next week......
DJM wrote:Evening Graham,
Tim Allman
Post by Tim Allman » Sat Dec 17, 2016 4:44 pm
Thanks for the speedy answers everyone. And, the caution is much appreciated LM.
OldStan
Post by OldStan » Sat Dec 17, 2016 7:54 pm
Low tech way is two nuts jammed together, remove using lower nut. Depends on how tight they are in the case whether it will work or not.
63 CA78
