Hello everyone! First time posting, and recent forum member. I just picked up a 1966 CB77 (as per the sticker on the harness). Unfortunately, it's missing standard (60mm) pistons!
I realize these are available new, primarily in kits with the rings, pins and clips, and may very well go that way; however, I wanted to post to see if anyone has some used but serviceable pistons they'd like to part at a reasonable price. I'm in South Carolina, USA.
I'm really enjoying learning about these classics!
Thanks in advance, guys!
'66 CB77 standard 60mm pistons
Hoosier Tom
Hey there! Thanks for your reply! I did measure the cylinder sleeves with the right tool/method, so I am certain I need std. 60 mm pistons. While I certainly am not familiar with these motorcycles, I'm pretty knowledgeable about mechanicals generally. I just recently rebuilt my VW Type 3 engine from the bottom up !☺️ Fortunately I don't think I'll need to do the same with the CB77, but it does certainly need pistons! 😂 Anyway, again thanks, and any ideas for some reasonably priced pistons would be great!
Thanks Randy. The whole "steel cylinder sleeve in the aluminum case" thing has me a little confused. When you mention boring the holes for larger pistons, are you referring to boring the sleeves, or the case? If the latter, wouldn't I then need new oversize sleeves as well?
I guess the more succinct way of getting to the heart of the matter is to ask: can I bore out the existing sleeves by, say, .25 mm, and then get .25 mm oversize pistons?
Thanks, and I apologize in advance for my ignorance!
Stephen
Stephen
