Hey all,
I'd like to get rid of the heel/toe shift lever on the dream - it gets in the way...a lot...
I don't want to cut this one up - I'll just throw it in the box of extra parts for the next owner
Anyone know what other "regular" lever will slide onto the splines ?
Thanks !
Dan
Eliminate heel toe shift lever
danielzink
Gear shifter.
I think the gear change shaft on your bike is pretty well a Japanese standard sized spline, if so there will be plenty of levers which will fit.
Why not have a walk round a bike breakers yard and pick up a few that look something like then see which you can 'fine tune' to your requirements.
What do you have against the standard toe and heel arrangement?
My first bike was a C92 Benly which also had a toe and heel pedal, don't remember it being a problem although, as it was my first bike' I didn't have experience with anything else (until I bought my first CB77) This was a looonnng time ago!
Geoff Hastings
danielzink
Re: Gear shifter.
Big feet and the way I position my feet on the pegs...DJM wrote:I think the gear change shaft on your bike is pretty well a Japanese standard sized spline, if so there will be plenty of levers which will fit.
It's a personal preference thang...
Re: Eliminate heel toe shift lever
CL72/77 Scrambler lever?. ...........lm
danielzink wrote:Hey all,
Thanks !
Dan
