looking for early cb77 front fender for a 63. i have a late superhawk fender that is up for trade for a late one. i'm also looking for a right side engine cover and dynamo cover for a superhawk.
Jeremy
Hi, Don't know if you already found what you needed but if you hav'ent i may be able to help. I scraped out a stuck superhawk for the tranny needed for my dream. Front fender is in pretty good shape but not sure what year, did'nt know there was a difference. Should have whatever else you might need. Atlas
Are ya aware that the CB trans gears are totally different than a Dream?. ....lm
Atlas wrote:Hi, Don't know if you already found what you needed but if you hav'ent i may be able to help. I scraped out a stuck superhawk for the tranny needed for my dream. Front fender is in pretty good shape but not sure what year, did'nt know there was a difference. Should have whatever else you might need. Atlas
PM sentAtlas wrote:Hi, Don't know if you already found what you needed but if you hav'ent i may be able to help. I scraped out a stuck superhawk for the tranny needed for my dream. Front fender is in pretty good shape but not sure what year, did'nt know there was a difference. Should have whatever else you might need. Atlas
Jeremy
The fender i need is one that will fit the steel slider fork leg. the center mount has a curve in it making it look kinda like the letter J. I also need the correct speedo, i need the tach and speedo rotate in the opposit directions, the headlight ring, starter soliniod, starter button assembly and wiring, generator cover, and a right side engine cover. The fender is what i need the most, pictures would be great to make sure its the right one. My e-mail is burnite2@hotmail.com.
thanks,
Jeremy
thanks,
Jeremy
