I have had the carb apart many times now and as soon as I start it up and open up the throttle one slide sticks. I've tried polishing the slide and the inside of the carb but no luck. It moves super smooth when it's put together. But if you run it then it sticks. Not sure if the heat is doing somthing but it's not real hot when first started. Any thoughts.
Oh right and this is on a 67 cl77.
Sticking throttle slide
79vetteguy
Sticking slide problem fixed
I was experiencing sticking slides in both carbs on a 1968 Super Hawk CB77 that I recently purchased. I tried loosening the nuts holding the carbs to the head and now both slides are working fine--no sticking. Thanks for this great tip--I was considering replacement carbs until now.
