Ok, so I made a mistake. I bought these replacement levers on ebay for my 1965 CA77 Dream with the early handlebars:
http://www.ebay.com/itm/200709395089?ss ... 1497.l2649
Unfortunately, the stock mirror stems are 8mm x 1.25 fine pitch and the ebay lever perches are 10mm x 1.25. Are there other options besides taking all this stuff back off and replacing it? I'm assuming that some mirrors are 10mm. Does anyone know of a place that sells a set that looks close to stock but in 10mm?
Mirrors... options...CA77 Dream...
A 8mmx1.25 helicoil will thread right into the hole on that perch, and allow you to use your mirrors.
Davo
http://www.ebay.com/itm/M8-X-1-25-Perma ... 4601765e31
Davo
rzgkane
Thanks.davomoto wrote:A 8mmx1.25 helicoil will thread right into the hole on that perch, and allow you to use your mirrors.
Davo
So a Heli-coil sold as an "8mm x 1.25" would have an outside dimension of 10mm x 1.25?
If so, I'll just buy the inserts. Otherwise, I'll need the entire thread repair kit with the bit and tap included.
Ya need the kit. ............lm
rzgkane wrote:Thanks.davomoto wrote:A 8mmx1.25 helicoil will thread right into the hole on that perch, and allow you to use your mirrors.
Davo
rzgkane
I'm buying a couple of these. I think they'll do the job:
http://www.catalogds.com/db/service?dom ... duct=453_8
LOUD MOUSE wrote:Ya need the kit. ............lm
Davo
What ya going to make the new threads for the coil to fit into?. .......lm
rzgkane wrote:I'm buying a couple of these. I think they'll do the job:
Davo
