jets 2
abert51
jets 2
Post by abert51 » Tue Oct 07, 2014 8:51 am
bored enging 1965 0r 66 CL77 (1mm overbore) do I need to use larger pilot jets. Mains are now145's. Existing pilots are stamped 38mm and I was thinking 45mm. ??
bamacl
Post by bamacl » Tue Oct 07, 2014 1:00 pm
1.0 mm oversize should not require larger jets
abert51
need choke on to run??
Post by abert51 » Tue Oct 07, 2014 3:54 pm
I need to have the choke up pretty far to keep my 305 running when cold - nothing new there but after warming and I put the choke down the engin wants to die off at 0-3/4 throttle. good response at 3/4 throttle and up. Too much air in idle mix?, therefore the previous question on larger pilot jets needles are set at middle notch, slides synced, everything real clean. Using Emgo pod filters and these might be junk??
R100
Post by R100 » Tue Oct 07, 2014 4:11 pm
Not that hard to try one size up pilots.
Even if it tells you you're wrong, that eliminates one thing.
bamacl
Post by bamacl » Tue Oct 07, 2014 7:43 pm
Ok now we know the setup. Pods will make a difference. If you have larger pilot jets try them. If not try raising the needles which I feel sure you will have to do anyway. This will address the off idle/midrange and to an extent idle.
