                    Sprocket question
Cb72
According to the guys at david silvers the 35T rear sprocket is now discontinued. I can have one made by bc express from an alloy blank at a cost of £43 im guessing tax and post on top. So does anyone have a 35t sprocket they don't need or should I change the gearing for what is available ie 37t  or get one made? Opinions please.
						Try here http://www.sprocketsunlimited.com/ they will make you a sprocket and they are vey helpful.
						Re: Cb72
Tunster
If your bike has a 350 kit the 35 or 34 tooth sprocket is probably too much. A standard 305 used 30T I think.
Tunster wrote:According to the guys at david silvers the 35T rear sprocket is now discontinued. I can have one made by bc express from an alloy blank at a cost of £43 im guessing tax and post on top. So does anyone have a 35t sprocket they don't need or should I change the gearing for what is available ie 37t or get one made? Opinions please.
'60 C77 '60 C72 '62 C72 Dream  '63 CL72
Cb72
I'm just going off what was fitted when I got it. The sprockets aren't completely worn out so maybe I should wait until I have it running and see how it goes then decide which I need but I will still ring and see what they can do. Thanks guys.
						Re: Cb72
That would make a lot of sense. If you are going to use it on the road you probably will want different gearing anyway.
Tunster wrote:I'm just going off what was fitted when I got it. The sprockets aren't completely worn out so maybe I should wait until I have it running and see how it goes then decide which I need but I will still ring and see what they can do. Thanks guys.
