float setting
float setting
How much gas will be in the bowl if the float is set right in the stock carbs of the CB77?
Re: float setting
<br /><br />First, turn the gas valve on, then off, then when you pull the float bowl off, put it at the same angle it is normally at; the top of the gas should be around 1/8" inch below the top of the float bowl. This is not the official procedure, but should work fine, and thought this answer would be better than no answer.eddie wrote:<br />How much gas will be in the bowl if the float is set right in the stock carbs of the CB77?<br />
