64 cb72 and 66 cb77 lift handle correct for both?
thumper2146
Post by thumper2146 » Sat Jul 10, 2010 1:51 pm
ok so would a 64 cb72 have a lift handle from the factory as well as my 66 cb77?? when did they start putting them on?
thanks
CliffC
Post by CliffC » Sat Jul 10, 2010 5:43 pm
Thumper, I may be wrong but I believe they started installing them in 65. They will fit on any CB. Cliff
Paul Strassmaier
Post by Paul Strassmaier » Thu Aug 05, 2010 2:14 pm
I've wondered the same thing. I have a very nice CB72 and it was obvious to me that it never had the handle. Another friend of mine at the time told me that in 64 it came on the CB77, but not the CB72 (I think I'm going to add one to mine...)
thumper2146
Post by thumper2146 » Wed Aug 18, 2010 11:58 pm
thanks for the info looks like the cb72 will be handle-less:)
james
Post by e3steve » Thu Aug 19, 2010 8:24 am
The lift handle was, I believe, market-dependent; e.g. it was fitted to US models during '65 and onwards, but not necessarily other Euro, Domestic Jap or Canadian markets. It is a great seat-pan saver!
When fitting, get the height and angle right, as adjustment is quite fine between the handle fouling the shock absorber and the bracket wings the fender. I removed my rear wheel & fender and drilled/tapped a short M6 screw through the rear clamp and into the frame so as to prevent its position shifting under lift-load.
