Post
by G-Man » Tue Oct 24, 2017 5:35 am
Hi Rusty
Great looking project!
A little help with Flickr photos ......
When you are on this view. Click the arrow, circled.....
You get to this page. Select BBCode, select a sensible resolution - I find 800 x 600 works well.
Copy the highlighted text and then paste it into you post.
Good Luck....!
rustywrench wrote:Thank you all for the feedback. it is clear to see that since I don't have a title on this one the best I can expect is some nice parts to count on. I was hoping that the 300 series was a limited time import making it a rare find. I'll keep it around and maybe turn it into a logging road bike. Now on to setting up to post pics. Rusty
https://www.flickr.com/photos/153409479 ... res/HJnqTJ
https://flic.kr/p/YCXTZv
OK, it's a start. Still working on the process. Rusty
Post
by LOUD MOUSE » Tue Oct 24, 2017 7:37 am
Were usually brought over bu GI'S.
Hard to tell.
Does the points cover read type1 or 2?.
If 2 can you show coil? ............lm
rustywrench
Post
by rustywrench » Tue Oct 24, 2017 8:41 am
Thank you G, every step I take lately is a learning process.
Ed, I will be checking on that soon. Rusty
Ok this is as close as I can get.
DSCN0071 by
kenneth zukowski, on Flickr
rustywrench on Tue Oct 24, 2017 7:08 pm, edited 1 time in total.
Post
by LOUD MOUSE » Tue Oct 24, 2017 10:50 am
I see type1.
Does the harness show 1966?. ....................lm
rustywrench wrote:Thank you G, every step I take lately is a learning process.
DSCN0071 by
OOps I forgot to size it
rustywrench
Post
by rustywrench » Tue Oct 24, 2017 7:21 pm
Yes I see that now so what I may have here is a hodge podge of different things. MPH speedo, type 1 eng, throttle/switch assembly has a l/R winker switch, then the wire harness leaves me a bit confused. What I do have is a lot of good parts to use elsewhere. Rusty
Post
by LOUD MOUSE » Wed Oct 25, 2017 8:06 am
What's the engine number?. ............lm
rustywrench wrote:Yes I see that now so what I may have here is a hodge podge of different things. MPH speedo, type 1 eng, throttle/switch assembly has a l/R winker switch, then the wire harness leaves me a bit confused. What I do have is a lot of good parts to use elsewhere. Rusty
rustywrench
Post
by rustywrench » Wed Oct 25, 2017 8:53 am
cl300E 1000175
Ed, if you could delete your post with my quote this thread will not be stretched any more. Just thinkin'. Rusty
