CA77 Electric Start Maintenance Question
dreamhog
Post by dreamhog » Thu May 30, 2013 9:50 am
I have a 1966 Honda Dream CA77. When I purchased it the electric start did not work. I got a bit ahead of myself and took the starter off and had it rebuilt at a starter/generator vendor. After reinstalling it I determined the problem is internal. The starter chain spins just fine but the chain goes into the engine and is not turning the engine over internally.
Soon I am about to take on the endeavor of pulling the right side casing and tracing down the problem. Anyone who has experience with this repair is welcome to provide me with any advice before I get started.
Suggestions / Input / Warnings / Encouragment appreciated...
Dreamhog
Olive Branch, Ms
mike1969
starter
Post by mike1969 » Thu May 30, 2013 1:38 pm
You will probably have to rebuild your starter clutch. It has 3 small barrels and springs that usually need replaced. Rollers may also have flat spots.
You'll need a bolt to screw into the center of the clutch to remove it.
conbs
Starter
Post by conbs » Sat Jun 01, 2013 2:37 pm
Dreamhog,
Use the search function on this site. It has been discussed a lot. Once you get the rotor off it is an easy fix to replace the springs and rollers.
