Fused circuit
casamere
Fused circuit
Post by casamere » Thu Mar 08, 2018 1:34 pm
Hi Guys, After returning from a ride I noticed the horn, brake light and turn signals have failed, are these on a fused circuit ?? Lights and start button work ok.
Geoff Hastings
Post by Geoff Hastings » Fri Mar 09, 2018 3:21 am
I've had a quick look at the circuit diagram and the single fuse protects the feed to the ignition switch (red wire) As there is only one fuse it might be quicker to just check that fuse then go up to the ignition switch.
casamere
Post by casamere » Fri Mar 09, 2018 5:13 am
Thanks for that Geoff first thing I checked was main fuse but why just those three things when start button works on same switch as indicators.
Geoff Hastings
Post by Geoff Hastings » Fri Mar 09, 2018 10:14 am
The black and red wire from the ignition switch feed the stop light,neutral light,indicator relay, horn and ignition coil. As the bike was still running you can rule out the switch but I believe the black/red wire devides inside the head light so might be worth a look at the bullet connectors in there.
casamere
Post by casamere » Tue Mar 20, 2018 6:55 am
Hi Geoff, Located problem chafed wire from ignition, all sorted and thanks for feed back.
