Fused circuit
Fused circuit
Hi Guys, After returning from a ride I noticed the horn, brake light and turn signals have failed, are these on a fused circuit ?? Lights and start button work ok.
The black and red wire from the ignition switch feed the stop light,neutral light,indicator relay, horn and ignition coil. As the bike was still running you can rule out the switch but I believe the black/red wire devides inside the head light so might be worth a look at the bullet connectors in there.
