allen head bolts?
Allen head case bolts
Malcolm, they are zinc plated. If you want a picture, I can send it to a email address.Scram64
- h305 Moderator
Re: Allen head set
You need to compress the image, not resize.Scram64 wrote:........
I'll try to post a picture if I can get the size correct. Nope, won't resize.
If you have Microsoft Office Suite (Word, Excel, PowerPoint, etc.) right click on the file (where it's located and before you open it), choose Properties>Opens with... then left click "Change" button. Select Microsoft Office Picture Manager in the window that opens, and then OK all the way out. You only need to carry out this file-association once (for this type of file at least -- .jpg, .jpeg, .tif, .bmp, etc).
Now open the file with a double left click. On the Menu bar, above the opened image, left click Picture>Compress Picture then dot the "Documents" radio button in the r/h pane; click OK then Close and save/replace the file. It will now be about 10% of its previous filesize.
You should now be able to upload or insert it to a post.
