allen head bolts?
Izoomx2
Post by Izoomx2 » Fri Feb 21, 2014 3:42 pm
stainless
Scram64
Allen head case bolts
Post by Scram64 » Fri Feb 21, 2014 8:27 pm
Malcolm, they are zinc plated. If you want a picture, I can send it to a email address.Scram64
Re: Allen head set
Post by e3steve » Sat Feb 22, 2014 11:41 am
Scram64 wrote:........
I'll try to post a picture if I can get the size correct. Nope, won't resize.
You need to compress the image, not resize.
If you have Microsoft Office Suite (Word, Excel, PowerPoint, etc.) right click on the file (where it's located and before you open it), choose Properties>Opens with... then left click "Change" button. Select Microsoft Office Picture Manager in the window that opens, and then OK all the way out. You only need to carry out this file-association once (for this type of file at least -- .jpg, .jpeg, .tif, .bmp, etc).
Now open the file with a double left click. On the Menu bar, above the opened image, left click Picture>Compress Picture then dot the "Documents" radio button in the r/h pane; click OK then Close and save/replace the file. It will now be about 10% of its previous filesize.
You should now be able to upload or insert it to a post.
Repsol
Post by Repsol » Sat Feb 22, 2014 9:08 pm
Did you get your bolts yet. I was thinking of doing the upgrade as well. What seller on Ebay did you get them from?
Izoomx2
Post by Izoomx2 » Sat Feb 22, 2014 9:46 pm
prob. won't get them till wed. or so . the seller is tentmakermotors and the e-bay item # 301100926278 . says several sets avail.
Repsol
Post by Repsol » Sun Feb 23, 2014 6:30 am
Yup. I saw them. They are pretty much the only set that comes up when you type in the search. Could you please post as to their quality when you get them?
Izoomx2
Post by Izoomx2 » Sun Feb 23, 2014 7:55 am
will do !
