I need to order a starter clutch 28121-259-000.
Which on line supplier have you guys had luck ordering from ?
Also do you know if the starter clutch comes with springs and caps or is it just the housing and the other pieces must be ordered seperately ?
Thanks.... Happy riding from North Mississippi...
Where do I get this part ?The "clutch outer" that you refer to is a separate part that is no longer available from Honda. You might try Western Hills, Ohio Cycle, or Northeast Vintage Cycle for that. Look at your parts book carefully, the starter clutch assembly also includes three springs, caps, and rollers, as well as a knock pin, a plate, and three of the proper 6x25 "cross" (flat-head) screws. Most of these parts are available from Honda; I would check at "partzilla.com"
-48
