Testing my STARTER SOLENOID
murray-eliminator
Post by murray-eliminator » Mon Jun 13, 2011 12:28 pm
Is there a test i can do to determin if my Starter solenoid is working? I have to jump the posts to get my starter to turn over. and am trying to track down the problem with the start button not working. all the wires seem to be fine.
Post by davomoto » Mon Jun 13, 2011 12:30 pm
Make sure the black wire is getting constant power, and the yellow wire makes a good ground. When you push the starter button, it grounds that yellow wire. Usually the problem is in the bar switch.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
murray-eliminator
Post by murray-eliminator » Mon Jun 13, 2011 12:57 pm
Ok Thanks. will check it out.
murray-eliminator
Post by murray-eliminator » Mon Jun 13, 2011 1:11 pm
Ok checked it out and the SOLENOID is not working..
conbs
Solenoid
Post by conbs » Mon Jun 13, 2011 7:38 pm
You should be able to put the yellow and black wires across your batter and hear it click to make sure the winding is working. You can take the solenoid apart for added TLC as needed, too.
murray-eliminator
Re: Solenoid
Post by murray-eliminator » Mon Jun 13, 2011 7:46 pm
conbs wrote:You should be able to put the yellow and black wires across your batter and hear it click to make sure the winding is working. You can take the solenoid apart for added TLC as needed, too.
Yeah thats how i tested it. no clicks or any thing.. bought one on ebay. hopfully that will fix the problem..
murray-eliminator
Post by murray-eliminator » Sun Jun 19, 2011 5:01 pm
Well got the new Solenoid and the starter button workd as it should now!
