I am at a loss, I thought it was low compression but
silverclerk@gmail.com
Post by silverclerk@gmail.com » Fri Nov 19, 2010 8:16 am
Thanks for the reply consb, I'll take a close look at that tonight.
Post by e3steve » Fri Nov 19, 2010 8:18 am
Have you checked that the three starter clutch screws, on the inside face of the rotor, are fully tightened and 'staked'?
Post by silverclerk@gmail.com » Tue Nov 23, 2010 11:44 am
The bushing seems ok.
Post by silverclerk@gmail.com » Tue Nov 23, 2010 11:47 am
Hey Steve, what do you mean by "staked"? The 3 screws seemed good to me, screwed in slightly further than flush with the cover
Dgormley
Staking
Post by Dgormley » Tue Nov 23, 2010 1:14 pm
Silver, staking is a process used to keep screws from backing out. I use a small center punch or sometimes a chisel to smack a dent in between the threads and the screw. It doesn't take much to keep the screw in place..................D
Post by LOUD MOUSE » Tue Nov 23, 2010 7:47 pm
In the case of the rotor ya will see where HONDA used a sharp tool and hammered a line across the side of the flat head screw at the edge which is in contact with the tapered screw hole in the rotor.
And did 2 sides 90 degrees across. ...............lm
silverclerk@gmail.com wrote:Hey Steve, what do you mean by "staked"? The 3 screws seemed good to me, screwed in slightly further than flush with the cover
Post by silverclerk@gmail.com » Wed Nov 24, 2010 8:10 am
Ok, thanks guys. I will look at that tonight
