DianneB wrote:Stripping the original paint was SUCH A JOB I was thinking about moving to media blasting but found that "aircraft paint stripper" works WAY better than the lumber yard stripper! So it is onward and upward!
Dianne's C77
After 4 days of hard work and chemical stripper and a few days getting set up for media blasting, everything was moved back to the workshop.
The basting with recycled glass worked great! It only took about 2 hours to clean up all the corners and crevasses and move on to the self-etching primer.
Now it is on to the base coat for the candy paint.
What color base coat are you using?. ...................lm
DianneB wrote:After 4 days of hard work and chemical stripper and a few days getting set up for media blasting, everything was moved back to the workshop.
OOOOOOOOOOOOOH!
Lots of work but should be nice. .................lm
DianneB wrote:I am starting with a silver sealer over the primer, then metallic white - this will be the background colour for lace. After applying the lace, I switch to a medium aluminum coat as the foreground. After that, I spray candy purple and finish with clear-coat.
