Dianne's C77
Post by LOUD MOUSE » Mon Feb 08, 2016 5:05 pm
You are using the best liquid stripper out there. ...........lm
DianneB wrote:Stripping the original paint was SUCH A JOB I was thinking about moving to media blasting but found that "aircraft paint stripper" works WAY better than the lumber yard stripper! So it is onward and upward!
DianneB
Post by DianneB » Mon Feb 08, 2016 9:30 pm
LOUD MOUSE wrote:You are using the best liquid stripper out there.
I had used it back in the late 7's when I was rebuilding a 1946 airplane but hadn't seen it in decades so I thought the environmentalists got it - they seem to get all the good products banned.
DianneB
Post by DianneB » Mon Feb 15, 2016 12:43 pm
After 4 days of hard work and chemical stripper and a few days getting set up for media blasting, everything was moved back to the workshop.
The basting with recycled glass worked great! It only took about 2 hours to clean up all the corners and crevasses and move on to the self-etching primer.
Now it is on to the base coat for the candy paint.
Post by G-Man » Mon Feb 15, 2016 1:51 pm
Looking good.
Did you repair the crack?
Post by LOUD MOUSE » Mon Feb 15, 2016 2:04 pm
What color base coat are you using?. ...................lm
DianneB wrote:After 4 days of hard work and chemical stripper and a few days getting set up for media blasting, everything was moved back to the workshop.
DianneB
Post by DianneB » Mon Feb 15, 2016 4:42 pm
I am starting with a silver sealer over the primer, then metallic white - this will be the background colour for lace. After applying the lace, I switch to a medium aluminum coat as the foreground. After that, I spray candy purple and finish with clear-coat.
Post by LOUD MOUSE » Mon Feb 15, 2016 4:54 pm
OOOOOOOOOOOOOH!
Lots of work but should be nice. .................lm
DianneB wrote:I am starting with a silver sealer over the primer, then metallic white - this will be the background colour for lace. After applying the lace, I switch to a medium aluminum coat as the foreground. After that, I spray candy purple and finish with clear-coat.
