Boring costs?
jugger18
Post by jugger18 » Fri Jan 29, 2016 2:40 pm
OldScrambler wrote:Before you send your barrels.............do you have the pistons and rings in-hand? If so, send along with the barrels..........a PROFESSIONAL SHOP will bore each hole to provide the proper skirt-clearance..........and will usually ask if the application is for everyday-use or some sort of high-performance application. A 0.50 or 0.75mm over-sized bore will usually cure typical scores and pits in the liners.
I use and always recommend MELLENIUM TECHNOLOGIES.........in Plymouth, WI.........look them up with GOOGLE...........Last year I had several bores completed at a little less than $50 per hole..........of course I don't have expensive shipping because they are about 6-miles from my door. Your price may vary...........?
I have a NOS set of .50mm over. They did ask to have the pistons in hand when they do the boring.
Post by LOUD MOUSE » Fri Jan 29, 2016 2:48 pm
Any good shop HAS TO HAVE the NEW PISTONS to measure and bore for them.
I've never sent rings as the pistons are what's the bore measurement. .................lm
