clutch plate adjustment CL77
jbills
Post by jbills » Tue Oct 14, 2008 9:10 pm
I removed a frozen set of clutch plates and have separated them. They are now clean and re-installed but I don't know how tight to torque the spring bolts. Can anyone help me here. Also, where do I position the kick start cog(?). I have a manual but like most, it does not address either of these questions.
Re: clutch plate adjustment CL77
Post by LOUD MOUSE » Tue Oct 14, 2008 10:13 pm
Pull the socket to hard/firm on the spring bolts.
The kick lever must be at at least 11:00 after ya install the cover. ...........lm
jbills wrote:I removed a frozen set of clutch plates and have separated them. They are now clean and re-installed but I don't know how tight to torque the spring bolts. Can anyone help me here. Also, where do I position the kick start cog(?). I have a manual but like most, it does not address either of these questions.
RIDE IT DON'T HIDE IT!
jbills
Post by jbills » Wed Oct 15, 2008 5:38 pm
Thanks Mouse,
I will loosen up the bolts as I cranked down on them previously...
[quote="LOUD MOUSE"]Pull the socket to hard/firm on the spring bolts.
[quote="jbills"]I removed a frozen set of clutch plates and have separated them. They are now clean and re-installed but I don't know how tight to torque the spring bolts. Can anyone help me here. Also, where do I position the kick start cog(?). I have a manual but like most, it does not address either of these questions.[/quote][/quote]
