Restore a 305 Dream 1969
Johnm32073
I am think of Restoring my 305, The only thing I am not good at is the engine. It runs very well, well it did until I tried rebuilding the carburetor (Dumb idea From Me) The rest of the bike I can pretty well do, But before I jump into the water I don't want to sink. Is very hard to dissemble, paint and put back together Paint and polish, i can do and line the tank I did that already Be my 1st motorcycle to take apart.
Dr. Frankenstein
Hi John -
The best way to do it is get a manual, socket set and some open-end wrenches and go for it!
Order a complete gasket and seal set on Ebay; you'll need it.
Its also a good idea to replace ALL the metric engine screws with Allenhead-type screws/bolts. The original JIS (Japanese Industrial Standard) screws are crap, and will more than likely strip out if you're using a regular Philips-head screwdriver. I use a set of VESSEL Megadora JIS screwdrivers exclusively on my Japanese bikes, and I use them ONLY on Japanese motorcycles. Visit Picclick.com or Ebay for a nice set; they're not too expensive, and worth every penny.
Fastenal.com is a good source for the Allenhead screws; Lowes, too, or maybe Home Depot.
This is One of the manuals I use, on Ebay right now for a really good price:
https://www.ebay.com/itm/283439245392
This is also a good page for free manuals, but you'll have to download them and print them out:
https://scramblercycle.com/pages/literature
Be sure to download the Honda Parts Catalog H/C 37465 too - it shows you how everything is supposed to go together, with their part numbers; its very nice to have.
Also note that the REAR WHEEL AXLE of the CA77 is perfect to remove the generator (the round thing on the side of the bike that the stator magnets go around). Just slide out the axle and screw it in to the hole of the generator until it pops off; then when you put the generator back on, it simply presses into place with the generator bolt. This is good to know.
Also, on the carburetor, the screw CLOSEST to the engine head is the Air/Fuel mixture screw; the screw FARTHEST from the head is the Idle Adjusting Screw. Gently screw them both IN all the way until you feel a 'soft seat', then back each one out about 1 1/4 turns; it takes a bit of playing with, but that should be a good starting point to get the bike dialed in.
Hope this helps!
-John
Hope this helps!
-John
Do not turn the IDLE/SPEED Screw all the way in then out 11/4 turn.
The engine will REV to HIGH RPM. ....................lm
Dr. Frankenstein wrote:Hi John -
Hope this helps!
-John
Dr. Frankenstein
Dr. Frankenstein
