Speedometer drive oil seal
305martin
Post by 305martin » Tue Nov 19, 2019 1:59 pm
Has anyone replaced the oil seal on the speedo drive? I have found 2 part numbers: 90752-250-000 and 90752-253-000. The "250" for early frame numbers I think. Neither of these fits my Dream. I have 3, all are the same and all are around frame numbers CA78-1013261. The speedo drive is the same for all 3. The oil seal has a number embossed on it: TC 34 48 6.5 Y1. Any ideas?
Re: Speedometer drive oil seal
Post by LOUD MOUSE » Tue Nov 19, 2019 5:12 pm
34 48 6.5
Order a seal with that number. ..............lm
305martin wrote:Has anyone replaced the oil seal on the speedo drive? I have found 2 part numbers: 90752-250-000 and 90752-253-000. The "250" for early frame numbers I think. Neither of these fits my Dream. I have 3, all are the same and all are around frame numbers CA78-1013261. The speedo drive is the same for all 3. The oil seal has a number embossed on it: TC 34 48 6.5 Y1. Any ideas?
DJM
Oil seal,
Post by DJM » Tue Nov 19, 2019 6:57 pm
If it's a 'standard' size seal you should get one from a bearing specialist supplier, much cheaper than a Honda part too. Just quote the sizes or search on line, an oil seal is an oil seal, well mostly anyway!
Re: Oil seal,
Post by G-Man » Wed Nov 20, 2019 2:13 am
DJM
Indeed! Just to help our friend a bit more, those numbers - in millimetres - are Inside diameter, outside diameter and thickness.
DJM wrote:If it's a 'standard' size seal you should get one from a bearing specialist supplier, much cheaper than a Honda part too. Just quote the sizes or search on line, an oil seal is an oil seal, well mostly anyway!
