Rotors
joeweir1
Rotors
Post by joeweir1 » Fri Apr 04, 2008 12:11 pm
I was reading an old post that a Rotor marked CB72 is better than a CB72(L).I have one that came off of a CA72 marked with C72, all the others on my CA77's have the C72(L).Can I assume the C72 is the better one like on the CB72?thanks
Re: Rotors
Post by LOUD MOUSE » Fri Apr 04, 2008 12:35 pm
Yes. The magnets are stronger. .............lm
joeweir1 wrote:I was reading an old post that a Rotor marked CB72 is better than a CB72(L).I have one that came off of a CA72 marked with C72, all the others on my CA77's have the C72(L).Can I assume the C72 is the better one like on the CB72?thanks
joeweir1
Post by joeweir1 » Fri Apr 04, 2008 12:48 pm
Thanks LM-Think I should swap it out?Joe
P.S. Did you get my PM acouple weeks ago about Carb. gaskets for my CA77.thanks
Post by LOUD MOUSE » Fri Apr 04, 2008 2:30 pm
It will charge better.
????????????????. .....................emo
joeweir1 wrote:Thanks LM-Think I should swap it out?Joe
joeweir1
Post by joeweir1 » Fri Apr 04, 2008 3:42 pm
I'll PM you again.thanks
Spargett
Post by Spargett » Sun Dec 06, 2009 11:15 am
I've always wondered what was up with my rotor/stator. I noticed that it was stamped C72. PO seemed to have no aversion to adding a number of parts from CL's and Dreams.
Mine has the LT & FT carved in with some sort of dremel. Do the dreams not come with that stamped on? How does one go about determining the proper LT & FT marks?
Wilf
Post by Wilf » Sun Dec 06, 2009 11:52 am
Scott,
The LF and LT marks should be exactly 180 degrees from the F and T marks. You could make your own marks, as the two in the photo don't seem to be exactly opposite the stamped F and T.
Wilf
