Ed Moore is the man!!!!!!!!!!
Little minor stuff, but what a difference!!!!!!!!!
THANKS ED
Rough running issues 1966 CL77
- Contact:
Re: Runs like a champ
Took um off I suspect. ...........lm
eyedragaknee wrote:Ed Moore is the man!!!!!!!!!!
THANKS ED
RIDE IT DON'T HIDE IT!
- Contact:
Sharing information
.....Pilot error, and not the carb kind.
I had put new intake tubes on the carbs and wanted to keep all the crap out till I got the high dollar honda air filters. I had some foam air filter material that I put over the ends to do that. It isn't the dense foam like a dirt bike. It is see through and seemed it would flow real free.
Took that $hit off as well as the 3 ft long tubing the PO had put on the carb bowl vents. Moved the clip up to the second notch from the top(leaner) and it pulls strong and runs smooth.
Thanks to both of you and the other many posts I went through just getting it to this point.
JR
JR
