                    Rocker arm tool ?
Rocker arm tool ?
All my manuals specify a special tool to remove rocker arms.I don't have one and would like to know if the job can be done without or can anyone explain how it works so maybe I can make one ?Thanks for any advice.
Re: Rocker arm tool ?
Just punch the end on the inside of the head and pop it out where the case stud slot is.
No screwing in or out and no special tools. ............lm
Look at the end of the pin and you will see it can be punched to the outside enough to put a pry tool and pop the pin out. ................lm
inog1 wrote:All my manuals specify a special tool to remove rocker arms.I don't have one and would like to know if the job can be done without or can anyone explain how it works so maybe I can make one ?Thanks for any advice.
									RIDE IT DON'T HIDE IT!
jwbert wrote:Thread a 6mm bolt, around 75mm in length, into the end of the rocker arm pin, clamp a vice grip to the head of the bolt, perpendicular to the length of the bolt and tap the pin out with a hammer hitting the vise grip. Works quite well. jwbert
						Rocker arm tool
Thanks for all the replies.All were helpfull, and the four pins are now all out without benefit of any special tools.Once again this board has proven its usefulness !   Thanks again all, and HAPPY HOLIDAYS.
