1965 CA77 Transmission question
JeffW
Post by JeffW » Fri Jan 30, 2009 9:52 am
Hello All!
Last night I removed the clutch from my bike project and noticed that 1 of the 2 wires that circle the center of the clutch is missing. My questions are, what is the purpose of these wires and will the clutch operate with out one of them? btw the clutch has 5 friction discs that have the aluminum core, they are 3.75 mm thick.
I have spent hours reading old posts and was unable to answer these questions.
You may notice that this is my first post as well as my first motorcycle project.
Thanks
Jeff
jeffw@liesch.com
Re: 1965 CA77 Transmission question
Post by LOUD MOUSE » Fri Jan 30, 2009 4:51 pm
The wires helped the disc to not stick together and release a LITTLE BIT BETTER as ya rode the bike. Missing one isn't a big deal. Was it the first or second wire that is missing? Not to worry about the thickness. Just be sure the friction material is all there and not rusted. ...........lm
JeffW wrote:Hello All!
Thanks
Jeff
jeffw@liesch.com
RIDE IT DON'T HIDE IT!
JeffW
Post by JeffW » Fri Jan 30, 2009 8:20 pm
Thanks for the reply Loud Mouse! That is what I was hopeing to hear.The missing wire is the one you would first come to as you remove the discs and plates one by one from the outside inward. That's kind of a round about way of saying it but I think you will understand. All the friction material is there and no rust on the plates. So back together it will go. Off to NAPA to get some 30W non-detergent oil. Thanks again, I'm sure I will need this forum many times in the near future.
Post by LOUD MOUSE » Fri Jan 30, 2009 8:26 pm
The clutch should be good as you install it.
Have fun Jeff. ............lm
JeffW wrote:Thanks for the reply Loud Mouse! That is what I was hopeing to hear.The missing wire is the one you would first come to as you remove the discs and plates one by one from the outside inward. That's kind of a round about way of saying it but I think you will understand. All the friction material is there and no rust on the plates. So back together it will go. Off to NAPA to get some 30W non-detergent oil. Thanks again, I'm sure I will need this forum many times in the near future.
eyedragaknee
clutch wires
Post by eyedragaknee » Fri Jan 30, 2009 8:45 pm
I have heard that they get broken and end in the oil pump. Is it best to just leave them out completely?
eyedragaknee
clutch wires
eyedragaknee
clutch wires
Post by eyedragaknee » Fri Jan 30, 2009 8:46 pm
