Krylon Dull Aluminum 1403
maia
Post by maia » Thu Oct 22, 2009 10:27 pm
I got tired of hunting around for the elusive "dull aluminum" and settled on a real engine paint from Duplicolor, engine enamel CDE 1615 Aluminum and then clear coated it. Looks great if you ask me, I'm not doing a 100 pointer. Check out my resto posting for a look but of course it doesn't translate perfectly.
Wilf
Post by Wilf » Fri Oct 23, 2009 8:57 am
Here's the box...
brewsky
Post by brewsky » Fri Oct 23, 2009 6:56 pm
THANKS, Wilf,
Now at least I know what to order!
By the way, I purchased some high temp aluminum paint for the header flanges which appears to be pretty close.
Pics below:
Wilf
Post by Wilf » Fri Oct 23, 2009 7:01 pm
Thanks for that. I'm thinking I will have to repaint my header flanges/collars and I don't know if the Krylon 1403 will do the job.
brewsky
Post by brewsky » Sun Oct 25, 2009 5:07 am
No problem.
I'm thinking I will just use the Rustoleum for the engine cover, starter, horn and triple clamp cover as well since it looks close enough for me.
See more pics in the other recent thread on Krylon.
Thanks again,
Brewsky
big-b
Post by big-b » Fri Mar 19, 2010 9:02 am
I've also only been able to find the interior use only version. Although many places had it listed in their computer system and interior/exterior even though the can says interior only. I think i'm going to try to find something else. The Duplicolor cast coat aluminum looks real close.
Brian
busaken
Post by busaken » Fri Mar 19, 2010 12:46 pm
i bought a sandblasting cabnet disassembled my 305 engine blasted it clean put cases in a part cleaning tank then used brake clean to hose down engine cases anr used compressed air to blow off cases and all oil galleys then i powdercoated engine cases cylinder,cylinder head and covers a dull silver. engine looks great have a pic on my 63 dream come true restortation project under busaken
