I am pretty new to restoration of motorcycles, but I thought a few of you may not have used either of these products and have found them to be lifesavers. The first is PB Blaster penetrating oil; I spray my fasters down for a few days before even trying to loosen them. I am just taking apart a Superhawk and could almost do it with my hands; the fasteners wouldn’t budge before with a wrench.
http://www.pbblaster.com/products.html
The cheapest place I have found to buy it is Home Depot.
The second is a Progressive shock spring compressor it’s the best $45.00 I have ever spent takes a shock apart in less than 60 seconds. Their was another thread on the board about this between Loud Mouse and Someone else,
http://www.bikebandit.com/product/13181 ... =338726025
I thought a few of you might not know about these thought I would post it.
Thanks,
Kirk
PB Blaster and Shock Disassembly
2-1966 CB77 Projects
1965 CB77 Partsbike
1967 scrambler pile of parts
1972 Cb350
1965 CB77 Partsbike
1972 Cb350
OK, what's the difference between "PB 50" and "PB Penetrating Catalyst" ??
bikedoctor99
In August '09 a friend generously gave me an original and stock '63 CB77!! Excited because I hadn't been on one since 1970, however there is always a hook in a freebie---this poor bike was stored outside for more than a few decades in north N.J. and was , as you can imagine, very weather beaten (lots of rust and serious corrosion). What was I thinking?
For it's dissection I used Aerokroil, a little pricey but great results-- it freed up the ignition switch, unstuck a seized piston, apparently the intake valve was open (there were mice living in the air filters)-- so you can imagine the corrosion in the barrel. Lots of Aerokroil in both barrels, a good sleep and in the AM coffee, more Kroil, propane torch, hammer + wooden block= done deal!
P.S. prior to the hammer I pried the cylinder up, other piston free and clean: crank & big ends OK- wedged a choice piece if wood under the barrels to dampen the shock and whacked away.
Moral: coffee, Kroil, hammer and block-- essential tools.
