New to the forum! Dream Project!
1slohonda
Post by 1slohonda » Mon Dec 14, 2009 12:51 pm
Yeah i havent decided what im going to do about the fron fender I think that I may use that one with a much taller profile wheel that will close that gap. I will pm the mailing adress to my house thanks
Joseph Allen
1slohonda
Post by 1slohonda » Tue Dec 15, 2009 10:55 am
heres the good and the ugly! Sorry they were in worse shape, upon removing the pipes i noticed the rust !
i tried the wd40 in the block no luck looks like im going to rebuild it any good suggestions!?
brewsky
Post by brewsky » Tue Dec 15, 2009 5:41 pm
Well, those look beyond my welding capabilities!
Before you tear into the engine, make sure nothing else is causing the "seisure", ......ie jammed sprocket chain, stuck in gear, stuck clutch etc.
Get & read the manuals before you start.
1slohonda
Post by 1slohonda » Tue Dec 15, 2009 8:37 pm
Yeah it will roll in neutral, and the 2 piston holds fluid when I sprayed the wd40 the other side it went through to the pan so i am assuming the 2 pistion is seized, I ordered the two CDs on here and now I am awaiting delivery hopefully before I goe to the beach so I can read up on it! I'm am looking forward to rebuilding it so I can have a fresh" motor maybe 30 over kit!
1966 Honda Dream ca77 rat bike/ In the works
2009 Yamaha R6 White
brewsky
Post by brewsky » Sun Jan 17, 2010 10:59 am
If you are still looking for a tank, here's one on ebay, reasonable.....at least for now!
http://cgi.ebay.com/ebaymotors/ws/eBayI ... K:MEWAX:IT
Onemilewest
Post by Onemilewest » Sun Jan 31, 2010 9:39 pm
I have a tank left over from my rebuild. I also did a rat all black, red wheels and whitewalls. I hade to pull the right side apart. I will have it back together and take a few pics.
Anyway, the tank has been sand blasted clean, but rust inside. I learned to fill the tank with old nuts, bolts, screws, you name it with some MEK and shake like hell for about a week and it will strip the rust. Let me know if you want it. Shouldn't be much to ship.
Onemile
