3rd gear binding
versuspop
Post by versuspop » Sat Mar 27, 2010 5:43 pm
Seems to be the case, with further exploration, that the problem is not there if I spin the gears a good 10 times, or so, before I switch gears. Which makes sense, since you don't normally switch rapidly from one gear to the next with out the gear set spinning a few hundred times in between, at least...
teazer
Post by teazer » Sat Mar 27, 2010 7:13 pm
I could be wrong, but I think all you are seeing is the fact that the dogs will not engage until the shafts rotate a few times so that the dogs line up.
if they go in OK and are not binding after a few rotations, then it's not an issue.
honda brian
ca77 gearbox
Post by honda brian » Mon Mar 29, 2010 3:52 am
Looks good to me mate. It will be spinning a whole lot faster than you can turn it. The gear selection should not be a problem.
Brian.
