Ugly Betty
Original k/s angle
Post by e3steve » Sun May 23, 2010 12:19 pm
Maybe you can get a visual on these pics, guys.
Wilf
Post by Wilf » Sun May 23, 2010 12:35 pm
Thanks for the pics, Steve.
These aren't some of those tricky photos that can sometimes lie, are they? (I've had some experiences with those!) I see that the ad depicts a black tail-light housing, so I'm just checking...
I'm debating right now as to what would be the easier fix: get the wrench out and re-position the lever, or, use PhotoShop to 'rotate' the lever and re-post my photo! :)
Wilf
Post by e3steve » Sun May 23, 2010 12:42 pm
Wilf, you slay me! ;D
It just sits uncomfortably close to the right shin when it's that high. In your situation I'd pull the r/h casing, make sure that you get full lever movement without straining the return spring, then refit the casing. I just hold the k/s pedal so that it just touches the casing flange where the stator cover fits; slide it over the k/s shaft and let the lever return to its natural static position, folded pedal tip about 20mm from the casing flange.
I noticed that, too!
Wilf
Post by Wilf » Sun May 23, 2010 12:55 pm
That's too much work--I'm going with PhotoShop!
I'm pretty sure I've got everything inside the casing correct, so shouldn't I just be able to pull the arm off, rotate one or two splines and slip it back on?
Wilf
Post by LOUD MOUSE » Sun May 23, 2010 1:08 pm
HONDA in their wisdom indexed all the KS parts so the lever will be at a position which has it clearing your arch and gives the best kick angle.
If ya "Do It My Way" ya will have at least one problem with the lever position/angle.
Here is a pic of the index punch location. . ..............lm
e3steve wrote:Wilf, you slay me! ;D
Wilf
Post by Wilf » Sun May 23, 2010 1:18 pm
Thanks for the pic, LM. I should be able to fix the position accurately from that.
Wilf
Post by LOUD MOUSE » Sun May 23, 2010 1:24 pm
Ya welcome. .............lm
Wilf wrote:Thanks for the pic, LM. I should be able to fix the position accurately from that.
Wilf
