CL / CB / CA Crankshafts - differences
Apart from the obvious 360 / 180 layouts I am interested in which cranks have the little hole in the rotor end of the crank to lube the starter clutch (?).
I have a couple of CL77 cranks with no hole but I also have a NOS C72 crank with no oil hole. My rusty CB77 crank has the hole and I need to source a new crank for that motor. I cannot see where the oil comes from for this hole and wonder why it is not there on the C72 crank. Am I missing something?
The oil for that hole comes through the middle of the tapered shaft.
The area ya describe lubes the right side crank bearing.
Could it be the crank the feller has is for the TYPE2 CL72?. ............lm
Wilf wrote:Oil comes from the right front stud. There is a depression in the block casting that leads to a drilled passage down to behind the starter clutch. The passage is visible when you lift off the cylinder base gasket.
Wilf
LM
I wondered that but the crank is in a C72 marked box. Maybe some one thought it was C72 and dropped it in there. I'll have to get the diamond burrs out and put a hole in there.
Thanks for the help.
